Forums >> Revit Building >> Technical Support >> Hidden Line Rendering Issues. Lines appearing through solid surfaces.
Wed, Nov 14, 2012 at 5:26:22 PM | Hidden Line Rendering Issues. Lines appearing through solid surfaces.
xman5021
As mentioned in the title above, we are having issues with lines appearing in our hidden line renderings. This is mostly when viewing an object from far. The objects are typically purlines supporting our roofs. The roofs themselves are solid, and when you view the rendering up close (through scrolling), they disappear, appropriately.
Anyone have a solution for this. This is becoming very tedious to correct through the linework tool and hiding objects.
Thanks!
Thu, Nov 15, 2012 at 9:11:56 AM | Hidden Line Rendering Issues. Lines appearing through solid surfaces.
xman5021
Anybody? Using the linework tool to clean up this graphic glitch is wasting man hours and in turn money.
Thanks!
Thu, Nov 15, 2012 at 9:32:27 AM | Hidden Line Rendering Issues. Lines appearing through solid surfaces.
Do they print?
Thu, Nov 15, 2012 at 10:50:04 AM | Hidden Line Rendering Issues. Lines appearing through solid surfaces.
xman5021
Yes.
Hidden line issues
Fri, Feb 13, 2009 at 7:59:38 AM
Solid filled region not printing with hidden line graphics style
Tue, May 13, 2008 at 12:13:21 PM
Line Styles Adjusting with Wall Hidden Lines?
Mon, Mar 12, 2018 at 12:58:29 PM
Printing vector changes solid to hidden line, shaded areas don't show correctly
Mon, Apr 20, 2015 at 10:56:21 AM
Lines aren't hidden in 3D view
Thu, Nov 15, 2012 at 11:01:33 AM
14
Page generation time: 0.7038
