27 Users Online (25 Members):
Forums >> Revit Building >> Technical Support >> Linked Door Schedules
1 Posts No Rating |
Revit Arch 2012. I have become involved with a Revit project that links several Central Revit models. One door schedule in the composite Revit file contains a field that is not listed in the linked central file door schedule. Other linked files are reloading with identical schedule fields. Any ideas? If I did not make myself clear...the basic jist is a schedule field exists in the composite file (contains several models) but it does not exist in the central file that is linked into the composite file.
Edited on: Wed, Nov 14, 2012 at 3:48:00 PM
So it isn't in that file.... If you need it there, then add it!
Linked file element parameters have to exist in the linked file in order to be scheduled.
Linked Revit Door Schedules not showing any data Revit 2015 |
Mon, Aug 3, 2015 at 12:07:22 PM
Linked door schedules issue |
Fri, Apr 3, 2009 at 1:13:48 PM
Schedules: Ie Door schedules! |
Fri, Jul 11, 2014 at 2:58:22 PM
Linked Door Schedule Problems |
Fri, Jul 4, 2008 at 3:37:38 AM
Door schedule with linked models - multiple models but door mark is the same |
Wed, Apr 22, 2026 at 3:01:42 PM
