Forums >> Revit Building >> Technical Support >> Exporting surface Geometry from Revit (2011 and above)
Mon, Nov 12, 2012 at 8:34:14 PM | Exporting surface Geometry from Revit (2011 and above)
phantomzzz
phantomzzz Avatar
As part of a council submission we have a requirement to provide council with a 3d model for them to use in their City  model project. The problem is that they will not accept any model greater than 5mb in size. With a 43 storey apartment building the only way to achieve this is to create a surface model that I can see.
Is there any way to export the surface geometry only from Revit or even open the revit geommetry in a third party application to generate the skin of the model only. We don't require any internals to the building, we simply need the exterior skin of the building.
Any thought would be greatly appreciated.
Tue, Nov 13, 2012 at 8:14:04 AM | Exporting surface Geometry from Revit (2011 and above)
We always model our buildings with the exterior on a seperate shell workset so that we can isolate it for occasions just like this.
Convert Surface to Joined solid geometry
Fri, Jun 14, 2013 at 3:18:24 PM
Autocad 2011 Solid To Revit 2011 Mass floor error
Mon, Feb 28, 2011 at 7:20:10 AM
3d splines into Revit Structures 2011
Thu, Nov 10, 2011 at 2:02:26 PM
How to cut mass conceptual divided surface
Mon, Apr 30, 2018 at 9:15:59 AM
Exporting topography points from Revit to AutoCad
Sat, May 23, 2015 at 11:21:41 AM
Page generation time: 2.3258
