Forums >> Revit Building >> Technical Support >> Stair Direction Display Problem
Mon, Nov 12, 2012 at 2:58:32 PM | Stair Direction Display Problem
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
I had read a similar post about this but I'm have not been able to apply it with any success to my problem. I created a short run of stairs that is only a couple of steps. When I create the run the arrow displays the direction as it should. But when I finish editing the stair displays the direction as down. The properties of the arrow has the display up arrow checked. The stiar in the 3d view is clearly going up from the start level to the finish level. When I go back in to edit the stair direction arrow displays correctly. Can someone help me understand where I went wrong? Thanks.
113193_STAIR_DIRECTION_PROBLEM01.JPG113193_STAIR_DIRECTION_PROBLEM02.JPG113193_STAIR_DIRECTION_PROBLEM03.JPG
Mon, Nov 12, 2012 at 3:32:53 PM | Stair Direction Display Problem
Which way was your stair created?  Hosted on the lower level and up or hosted on the upper level and down?
Mon, Nov 12, 2012 at 3:47:24 PM | Stair Direction Display Problem
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
It looks like all I have is start level and top level. It doesn't have a parameter for hosting to the floor or anything from what I can see. Usually the icon shows in the ribbon if there's ability to host right? I don't seem to have that.
Stair by boundary - stair direction
Mon, Aug 2, 2010 at 8:27:29 AM
Stair Display Problem for WWHub
Tue, Mar 17, 2009 at 11:31:55 AM
Grand stair problem revit 2014
Thu, Jun 15, 2017 at 11:19:46 AM
dual entry stair
Sun, May 29, 2011 at 11:05:33 AM
Problem witch stair visibility
Wed, Apr 9, 2014 at 7:08:58 AM
Page generation time: 1.0292
