Forums >> Revit Building >> Technical Support >> Gridline bubble problem (Revit 2013)
Mon, Nov 12, 2012 at 10:20:15 AM | Gridline bubble problem (Revit 2013)
OlavM
Hi! It seems like my gridline bubbles just doesn't exist, despite the fact that the box "show bubble" is labeled. I'm new in revit and have been looking for the solution too long already. Added screenshots too. Any help?
Thanks,
Mon, Nov 12, 2012 at 10:49:58 AM | Gridline bubble problem (Revit 2013)
GlobalDS
GlobalDS Avatar
4 Stars: 1 Votes
Try checking the 'Type' Settings. Click on the grid line, then edit the type in the properties bar. Under 'Symbol' ther is the
option of 'none' or of different types. If only the 'none' type shows up, you will have to load one.
www.globaldesignstudio.com
Be Inspired!
Mon, Nov 12, 2012 at 12:31:28 PM | Gridline bubble problem (Revit 2013)
OlavM
Only the 'Grid 1' type shows up and the only symbol is 'none'.. How or where I can load this kind of thing ?
Mon, Nov 12, 2012 at 12:50:32 PM | Gridline bubble problem (Revit 2013)
GlobalDS
GlobalDS Avatar
4 Stars: 1 Votes
The Grid 1 is fine, but currently your screenshot shows that the Symbol is <none>.
If you click on this <none> you should come up with a drop down menu with the default Grid bubble as an option.
If not you will have to just load it. Just go to Insert tab, load family, and search through the standard revit files for one.
Be Inspired!
Mon, Nov 12, 2012 at 3:49:30 PM | Gridline bubble problem (Revit 2013)
OlavM
Thanks! Finally found it.
Gridline manipulations propagating
Sat, Sep 7, 2013 at 4:08:22 PM
missing gridline
Wed, Oct 9, 2013 at 3:02:09 PM
Problem with Column bubble tag
Mon, Sep 14, 2009 at 3:46:07 PM
gridline 3D/2D
Thu, Jul 18, 2013 at 11:14:49 PM
problem with grid bubbles when printing in smaller scale
Fri, Sep 28, 2007 at 2:02:01 AM
Page generation time: 3.8509
