Forums >> Revit Building >> Technical Support >> Archtop Windows not working in R2013
Mon, Nov 12, 2012 at 10:17:18 AM | Archtop Windows not working in R2013
GlobalDS
GlobalDS Avatar
4 Stars: 1 Votes
I have an archtop window that works fine in R2012, but it doesn't work in 2013. There must be some difference in the way
2013 processes the file. Please check the attached file, it is adjustable in 2012, but I can't adjust the sizes in 2013. Can
anybody tell me why, or what I would have to adjust? It has something to do with the curves that 2013 won't flex, but I'm not sure what?
Thanks in advance.
www.globaldesignstudio.com
Be Inspired!
Thu, Nov 15, 2012 at 11:40:27 AM | Archtop Windows not working in R2013
GlobalDS
GlobalDS Avatar
4 Stars: 1 Votes
Has anyone had similar issues? Any Ideas? I had similar issues when upgrading from 2010 to 2011. It's frustrating that I can't upgrade because Autodesk changes the way it works, and some of my components stop working. Any advise would be appreciated.
Be Inspired!
Thu, Nov 15, 2012 at 3:26:12 PM | Archtop Windows not working in R2013
If that is the 2013 file then post the working 2012 file as well.
Sun, Nov 18, 2012 at 5:40:20 PM | Archtop Windows not working in R2013
GlobalDS
GlobalDS Avatar
4 Stars: 1 Votes
That is the 2012 file. It doesn't work properly in 2013.
Be Inspired!
Tue, Nov 20, 2012 at 11:28:14 AM | Archtop Windows not working in R2013
GlobalDS
GlobalDS Avatar
4 Stars: 1 Votes
Any Ideas? This is now the one file that is stopping me from being able to use 2013.
Be Inspired!
Tue, Nov 20, 2012 at 4:24:00 PM | Archtop Windows not working in R2013
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Have you tried opening the family in 2013 and flexing the family to see where the problem is? Or does the problem on exist in a project?
Edited on: Tue, Nov 20, 2012 at 4:24:23 PM
Wed, Nov 21, 2012 at 6:57:45 PM | Archtop Windows not working in R2013
GlobalDS
GlobalDS Avatar
4 Stars: 1 Votes
Sometimes we overlook the obvious! Thanks. Yes I had tried initially to flex it in 2013, but I did not spend enough time on it before trying to flex in 2012 and load to 2013.
Be Inspired!
Archtop Door Flexibility
Wed, May 4, 2005 at 6:43:01 AM
Need Rakehead windows......
Wed, Apr 22, 2009 at 1:15:12 PM
Can only square panels in curtain walls be converted to windows?
Wed, May 16, 2012 at 2:22:01 PM
Designjet printer driver w/ Windows 7 - 64bit
Thu, Feb 17, 2011 at 11:20:24 AM
adding mullions to archtop with trim
Fri, Oct 3, 2014 at 12:32:40 PM
Page generation time: 0.8280
