Forums >> General Discussion >> Revit Project Management >> Central Model Update issue MEP2013
Mon, Nov 12, 2012 at 8:40:47 AM | Central Model Update issue MEP2013
bassman
Im fairly new to Revit. I was sent a model, and I made it a central file. Then I created a Local file from that. Ive been working on that local file and syncing back to the central with no issues. The architecht sent me an updated model. When I try to sync to the new model, I get this message .. "Your Local file is not compatible with the central model", It says I have to create a new local file and copy paste any changes.,...I cant do that. Its too much work. I dont think the architect changed the version of Revit they are using halfway through a major project.
any ideas? Im using MEP 2013
Mon, Nov 12, 2012 at 8:45:43 AM | Central Model Update issue MEP2013
You should not have used the architects model.  You need your own model with the architect's model linked into it.  You need to read your HELP and on-line tutorials about the Revit file linking process.
Mon, Nov 12, 2012 at 8:50:44 AM | Central Model Update issue MEP2013
bassman
Thats what i was afraid of. So I is there any way to save my views and import them into a new project?
Mon, Nov 12, 2012 at 9:01:00 AM | Central Model Update issue MEP2013
bassman
It might be easier to link the new model, and delete the old model. but keep the work ive done.
thoughts?
Mon, Nov 12, 2012 at 9:09:32 AM | Central Model Update issue MEP2013
You could delete all elements that are not yours and link in the architect's model.
I always recommend that linked models be kept in separate worksets so that they can be completely turned off in views.
Updating a Central File
Thu, Aug 16, 2007 at 3:18:20 PM
Central Model rolls back to previous version
Thu, Jun 5, 2014 at 7:47:21 AM
Central/Local File Synchronizing Issue
Sun, Jun 23, 2013 at 2:33:20 PM
Visibililty issue when linking central files
Thu, Feb 24, 2011 at 1:54:29 PM
Converting Central Model to Basic Model
Wed, Jul 2, 2014 at 11:48:21 AM
Page generation time: 0.7252
