24 Users Online (22 Members):
Forums >> Revit Building >> Technical Support >> hide sections of section lines in plan
4 Posts No Rating |
I am using revit 2012 and have several section views in my project and they have jogs in them. Is there a way that I can hide those jogs? Right now I have the usual section line breaks in place, but where the section jogs there is still a funny looking corner in the middle of my plan. Any suggestions? and the masking region I am using is not working...
I don't believe you can remove the jog. I have alwyas kept it long enough so that you would know what it is. If you don't like that, then don't do a building sction. Use two sections.
4 Posts No Rating |
yeah i had explored using 2 sections (similar to an angled section cut from orthagonal) but that is too much of a hassle for this. I ended up just shrinking the jogs down so all you see on screen is a small dot which I can live with
Placed Sections on Sheet, Plan Cut Lines Disappeared, But the Sections Remain |
Sun, Dec 2, 2012 at 7:34:52 PM
Sections Referencing the drawing you want. Help Cheat! |
Fri, Feb 25, 2011 at 11:22:05 AM
Section Lines not showing up on a plan |
Thu, Jan 8, 2009 at 9:32:28 AM
Hide sections in all project except in a plan view |
Sat, Feb 4, 2012 at 9:46:23 AM
Create Section lines to place sections separately under project browser |
Mon, Sep 10, 2007 at 8:15:49 PM
