Forums >> Revit Building >> Technical Support >> show concrete only
Sun, Nov 11, 2012 at 10:17:33 PM | show concrete only
martinsachs
Hi all,
I am working in Revit 2013.
I am doing a project with a multi layered floor (concrete slab with insulation and different finishes) and as this slab has a few setdowns in the slab and several penetrations I would like to show the concrete layer only. I can't find a command for that so I am wondering if this is possible. If it is, can you then put dimensions to it and create a seperate drawing, which can be issued to the concrete guys onsite?
Thanks in advance.
Mon, Nov 12, 2012 at 5:46:05 AM | show concrete only
coreed
coreed Avatar
4 Stars: 16 Votes
i don't think there is a command this, but you should be able to create a new view and adjust the visibilty of things to achieve what you want, put dimensions on it, and drag onto a sheet.
hth
Edited on: Mon, Nov 12, 2012 at 5:46:48 AM
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Mon, Nov 12, 2012 at 5:53:00 PM | show concrete only
martinsachs
Thanks for the reply, but I can't adjust the visibility of the floor to show ONLY the concrete slab. I also tried to set the concrete layer as core element, but am still not able to "switch" the other elements of the floor off. If you have another idea please let me know.
Martin
Tue, Nov 13, 2012 at 7:26:05 AM | show concrete only
coreed
coreed Avatar
4 Stars: 16 Votes
If you have a multiple component floor. You will have to create the concrete layer as seperate floor that rest on top of the other components. you can align and lock the floors so that they move together.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Sun, Nov 18, 2012 at 6:15:04 PM | show concrete only
martinsachs
Thanks coreed,
this was not the answer I was looking for but if revit can't do it, it can't do it.
Martin
Sun, Nov 18, 2012 at 10:16:21 PM | show concrete only
sagarlondonites
You can convert the floor into 'parts'. Then you can apply a filter in view to show only the 'core' layers of the part.
Mon, Nov 19, 2012 at 7:53:20 AM | martinsachs
coreed
coreed Avatar
4 Stars: 16 Votes
Quoting martinsachs from 2012-11-18 18:15:04
Thanks coreed,
Martin
I think it's just a matter of how and not can't.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Precast Concrete Panels
Fri, Mar 31, 2017 at 12:28:39 PM
13
Concrete hatching ?
Tue, Jan 21, 2014 at 3:58:04 PM
How can I show concrete piles/piers beyond in a section view
Tue, Sep 20, 2005 at 6:59:33 PM
Getting my drop panel to show up with hidden lines correctly
Thu, Mar 22, 2007 at 9:53:53 AM
Concrete columns behaviour before and after placing concrete beams
Tue, Apr 1, 2014 at 1:58:43 AM
Page generation time: 2.3251
