Forums >> Community >> Newbies >> Room area calculation
Sun, Nov 11, 2012 at 2:42:16 PM | Room area calculation
JoBrowns
Thank you for your attention:Let's say I have a bunch of rooms/areas. They fall under 2 categories - room type A and Room type B. I want to create a schedule that will not only list rooms A and rooms B separately, and not only add up the total areas (i.e. total area of all rooms type A and total area of all rooms type B) but also to do a mathematical formula - i.e. Room A total area is multiplied by 1.414 and room B total area multiplied by 1.112. How do I do this in scheduling?I'm ok with calculations, but the problem is that it gets applied to ALL the items listed. I don't know how to do these calculations AFTER they have separated the room types, and each room type has its own formula.Please help!Thank you so much.JLB
Sun, Nov 25, 2012 at 2:28:44 PM | Room area calculation
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Shouldn't be hard.
Keep it simple and create two seperate schedules and 'Filter' each schedule to collect Room A's and Room B's. Then from there you can apply your calculation factor to each schedule seperately as required.
Ley us know if this works.
room area calculation
Thu, Jan 15, 2009 at 5:51:20 AM
Revit interior walls transmission area calculation
Tue, Oct 28, 2014 at 1:44:23 PM
Area calculation with dormer
Mon, Dec 6, 2010 at 8:43:26 AM
Room tags with area - area not showing up!
Thu, Aug 16, 2007 at 6:54:26 PM
Heat loss calculation formula
Wed, Apr 29, 2009 at 10:09:09 AM
Page generation time: 0.1990
