13 Users Online (11 Members):
Forums >> Workflow & Implementation >> API & Third Party Apps >> 2012: Adding surface connectors
1 Posts No Rating |
I'm stuck with connecting a conduit to a junction box in my model. How can I programmatically add a connector to the surface and connect it to a conduit connector? Documentation has no information about this issue.
In my case I have a family instance (junction box) with surface connectors and a conduit. I'm trying to connect them together in the model: private void ConnectConduitToBox(Conduit conduit, FamilyInstance box) In this case box.MEPModel.ConnectorManager.Connectors shows that there are about 8 connectors - one with type ConnectorType.End and others with ConnectorType.MasterSurface I cannot find a way to do this in the API. Maybe someone can give a hint - where to search for this info. I can provide a sample solution and a model to test this if needed Many thanks
Array/group pipe connectors |
Wed, Jul 14, 2010 at 4:59:44 AM
Nested Family (Connectors) |
Mon, Jul 6, 2009 at 9:08:00 AM
Schedule of Mechanical / Plumbing Equipment Connectors |
Wed, Feb 2, 2011 at 3:04:17 PM
Baluster connectors not staying parallel to railing. |
Mon, Apr 12, 2010 at 3:37:59 AM
Adding Material to Divided Surface |
Thu, Apr 17, 2014 at 10:40:12 AM
