15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> Curving sloped pads
1 Posts No Rating |
I am trying to model a curved driveway that is sloped. How do I get the top of the slab to be level? Point A is too high while point B lines up correctly with the slab to the right. Essentially it seems as if the slope arrow needs to be curved. Is this possible?
Use a "Slab" (you can control those points), instead of a "Ramp".
You could also create a subregion on the site, making a sketch with that curved shape. It will follow the slope of the site. Or, you could create the driveway with a split region, and then modify the individual elevation of its points.
Edited on: Thu, Nov 8, 2012 at 7:36:32 AM
Planta1 Revit Online Consulting | info@planta1.com |
I'm with Alf on this. I see no reason to model a thickness on roads so I always grade the site accordingly then spit the surface and assign my material.
Sloped inscribed building pads have topo 'walls' |
Wed, May 6, 2015 at 7:25:40 AM
Adjacent building pads: toposurface popping up between |
Wed, Nov 20, 2013 at 10:22:59 AM
Topography and pads trick |
Mon, Jan 14, 2013 at 2:53:18 PM
Building Pads...how to see existing pads when outlining a new one? |
Sun, Apr 10, 2011 at 12:39:55 PM
Topo PADS |
Sat, Sep 29, 2007 at 3:41:40 AM
