Forums >> General Discussion >> Revit Project Management >> scope boxes / far clip offset / view range
Wed, Nov 7, 2012 at 4:12:15 PM | scope boxes / far clip offset / view range
CreekFreak
Does anyone know if there is a way to apply a scope box to a section view yet, have the section retain the “far clip offset” of your section? Much like a plan still respects the view range that you have set if you apply a scope box to a plan view?
I am trying to apply the extents of a scope box to multiple sections so they share the same extents on sheets.
It seems that plan view can have a scope box and still respect view range settings (i.e. not look all the way to the bottom of the scope box by default)
It seems that sections can only look all the way to the end of the scope box (i.e. not respect far clip offset values)
Is there any way to control section view range using scope boxes? apply extents of the scope box in one plane but not both? (Just like plan views work with scope boxes)
Thanks for any input
Thu, Jan 10, 2013 at 11:37:28 AM | scope boxes / far clip offset / view range
CIMARAY
if I understand you correctily....then like the plan view section views also have grips to extend or shorten the view "scope". Just make sure the crop region is clicked to show, zoom out, and touch the border and adjust. Also, you can grab the little squiggley line and break the secvtions for better detailing.
Thu, Jan 10, 2013 at 12:30:49 PM | scope boxes / far clip offset / view range
Use view templates.  You can contol the far clip offset.
Mon, Aug 12, 2019 at 11:33:35 PM | scope boxes / far clip offset / view range
bitslap
I found a solution that satisfied my requirements for a series of sections with the same direction and extents, but different origins and clipping planes:
1. draw scope box with extents from origin of first section to far clip of last section
2. draw first section at one end of the scope box.
3. copy the section up/down/left/right as required to create series of sections
4. in each section, set scope box to previously made scope box, click apply, THEN RESET SCOPE BOX TO NONE
5. manipulate far clip of each section without affecting view orientation/size.
Wed, Nov 6, 2019 at 2:11:05 AM | scope boxes / far clip offset / view range
Kalpesh30
Kalpesh30 Avatar
Thanks for sharing the details, It would be helpful for me.
view range top clip plane
Sat, Jan 24, 2009 at 7:56:31 AM
View Range
Mon, May 17, 2010 at 4:48:55 PM
Exporting scope boxes to dwg
Fri, Jul 1, 2011 at 12:30:25 AM
Unable to Change Far Clip Offset
Tue, May 26, 2015 at 9:50:20 AM
Scope boxes printing, set not to print.
Tue, Feb 15, 2011 at 6:39:49 PM
Page generation time: 1.0630
