Forums >> Revit Systems >> Technical Support >> MEP 2012 - Error that causes windows to close.
Tue, Nov 6, 2012 at 10:15:09 AM | MEP 2012 - Error that causes windows to close.
dsaint
I keep getting an error when I click on a light fixture in a view where is states "An Error has occurred while drawing the contents  of this windows. this window shall be closed." It one of the most fustrating things to happen near the end of a project. I don't know if the model has been corrupted or what.It doesn't shut down the whole project, just the one window.
Anyone else run into this issue and what'd you do to fix it.
Any help would be very appreciated.
Thanks in advance.
Tue, Nov 6, 2012 at 1:06:00 PM | MEP 2012 - Error that causes windows to close.
Kathe33
I've had this happen also but I don't know why. I have more trouble getting  to run while I'm detailing using components It keeps telling me it has a fatelerror and saving to recovery file. This has happened over 10 times while I  was working today alone.
REVIT MEP 2012: Installation problem-Error 2343.Specified path is empty.
Fri, Apr 29, 2011 at 7:30:51 PM
Revit MEP 2012 View Port Error with Linked views
Tue, Sep 4, 2012 at 11:50:45 AM
Revit Architecture 2012 Compatibilty with Windows 10
Thu, Feb 14, 2019 at 4:59:13 AM
Cut a wall along a other wall
Fri, Sep 16, 2011 at 3:28:07 AM
Revit 2014 - Disappearing error message
Wed, Nov 6, 2013 at 4:12:48 PM
Page generation time: 0.4276
