Forums >> Revit Building >> Technical Support >> Tee beam as column?
Mon, Nov 5, 2012 at 11:51:38 AM | Tee beam as column?
ArchiN00B
ArchiN00B Avatar
4.5 Stars: 4 Votes
I'm doing a school project and trying to use a WT22x167.5 beam as a column. Obviously Revit doesn't want me to turn the beam vertically, but is there an easy way to do this, even if it requries editing the family?
thanks.
Tue, Nov 6, 2012 at 2:41:46 PM | Tee beam as column?
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I would just create a new column family that hs that particular size in it.  I would not use a beam as a column, thats asking for trouble in the long run.
How to extend top flange of beam (over top of column)?
Fri, Jun 15, 2012 at 10:35:08 AM
pipe tee size
Thu, Jun 7, 2018 at 3:50:08 PM
How to show beam column connection in plan properly
Fri, Nov 7, 2014 at 12:53:30 PM
beams not snapping to beam/column
Fri, Feb 19, 2010 at 4:30:22 PM
Cable tray tee
Tue, Nov 1, 2016 at 7:29:06 AM
Page generation time: 0.7725
