Forums >> Community >> The Studio >> dimensioning walls with variable thicknesses
Tue, Jan 17, 2006 at 5:31:08 PM | dimensioning walls with variable thicknesses
unicorn
Hi, I have built a model and have created particular wall types with internal and external claddings with thicknesses which are assigned materials and colors to them... for example a 120mm stud wall, with 30mm weather board and 10mm plasterboard. This is fine for generating a rendered image of your model, but when i go to dimension the walls, the dimensioning picks up everything. How does one avoid this problem of the dimensions showing say a 150mm wall, when all i want it to show is a 120mm stud wall on my working drawings?
Wed, Jan 18, 2006 at 2:38:33 AM | RE: dimensioning walls with variable thicknesses
eldados
eldados Avatar
4.5 Stars: 8 Votes
please search the forum, been answered b 4... : when you click on the dimension tool some options will come up on top, under "Prefer" choose center of core from the drop down menu. HTH Smile
Integrator
KarelCAD
Thu, Jan 19, 2006 at 4:58:32 PM | RE: dimensioning walls with variable thicknesses
unicorn
OK... thought so, but didn't come across it, but will have another look... thanks.
Wall join at ends of two walls with different thicknesses
Thu, Jul 17, 2014 at 1:21:31 PM
Dimensioning Angular Walls
Mon, Jan 16, 2006 at 6:34:07 PM
Dimensioning from the edges of walls?
Wed, Jan 9, 2008 at 10:23:09 AM
Wall dimensioning
Thu, Jan 19, 2006 at 5:28:48 PM
dimensioning oblique walls
Mon, Jan 10, 2005 at 5:06:00 PM
Page generation time: 3.2872
