Forums >> Revit Building >> Technical Support >> Help with Parameter in Family
Fri, Nov 2, 2012 at 10:10:39 AM | Help with Parameter in Family
BIMChimp
Hello all,
I need help getting a parameter working.  I have a family that has a mfr model number in it that depends on the overall width of the family.  However that width is flexible.  Is there a way I can get the manufactur model type to reflect the width as text with additional text?
I.E.  When width = 30" the model number should be: 689-30  If the width changes to 40" then the model number should be 689-40.
Is there a way to do that?
Thanks,
LJ
Fri, Nov 2, 2012 at 10:48:32 AM | Help with Parameter in Family
There are no text formulas in Revit .
Fri, Nov 2, 2012 at 11:00:20 AM | Help with Parameter in Family
alfmedina
alfmedina Avatar
4 Stars: 8 Votes
Yes, it is possible.
model (text parameter)
width = length parameter
model = if(width = 30", "689-30", if(width = 40", "689-40", "none"))
But, it is more appropriate to handle this by types, otherwise, you end up with random lengths that do not generate a model number.
Planta1 Revit Online Consulting | info@planta1.com
Fri, Nov 2, 2012 at 11:02:42 AM | Help with Parameter in Family
BIMChimp
If the width is flexible I can easily add a parameter to reflect certain text dependant on the width.  '
I.E: if(Width = 29", if(Rear Access Panel, if(Right Hand, "689R29", "689L29"), if(Right Hand, "689R29FB", "689L29FB")), if(Width = 35", if(Rear Access Panel, if(Right Hand, "689R35", "689L35"), if(Right Hand, "689R35FB", "689L35FB")), if(Width = 41", if(Rear Access Panel, if(Right Hand, "689R41", "689L41"), if(Right Hand, "689R41FB", "689L41FB")), if(Width = 47", if(Rear Access Panel, if(Right Hand, "689R47", "689L47"), if(Right Hand, "689R47FB", "689L47FB")), "INVALID WIDTH"))))
That is actually dependant on three parameters (Width, Rear Access Panel, and Right Hand) in the family.  I just want to add the width number into the outcome of a similar formula.
That's not possible then?
Fri, Nov 2, 2012 at 11:05:15 AM | Help with Parameter in Family
alfmedina
alfmedina Avatar
4 Stars: 8 Votes
I am saying, it is possible, as in my example, above.
Fri, Nov 2, 2012 at 11:10:13 AM | alfmedina
BIMChimp
Quoting alfmedina from 2012-11-02 11:00:20
Hey ALfmedina,
We were responding at the same time.  I have a similar equation that you suggested.  But you're right, it's tough when the width can be changed to anything.  The equation I just gave is actually from another model.  this current model will have a variable width that will not be consistant based on types.  But there's no way to reflect the width directly?
Thanks,
LJ
Fri, Nov 2, 2012 at 11:36:48 AM | Help with Parameter in Family
alfmedina
alfmedina Avatar
4 Stars: 8 Votes
If you are referring to concatenating any width value into the model text number, no. Only as shown in the example: if this length is this, this text is that. That is possible, concatenating, no.
Fri, Nov 2, 2012 at 11:53:19 AM | Help with Parameter in Family
BIMChimp
That's what I was afraid of.
Ok thanks anyways guys,
LJ
Add Family name to a shared parameter
Tue, Jun 23, 2015 at 8:50:48 AM
<Family Type> parameter can't be controlled by formula. What else can we do? [ 1 2 ]
Tue, Aug 27, 2013 at 3:53:53 AM
29
Family with coordinate parameter? - Revit 2010
Wed, May 12, 2010 at 3:45:58 AM
11
One family parameter has formula one has none
Wed, Jun 25, 2014 at 1:05:54 PM
top/base constraint as a parameter in family types
Wed, Sep 9, 2009 at 4:49:38 PM
Page generation time: 2.2815
