24 Users Online (22 Members):
Forums >> Revit Building >> Technical Support >> Joining 2 Beams
3 Posts No Rating |
I'm welding together 2 beams at differing slopes. What is the easiest way to show this in Revit? Attached is an example of what I mean.
you can't really join beams...
what you can do, i haven't ried it yet but i'm sure you can do it, is open yout vertical post family and attach a void to the top of it with angle control parameter, than you can adjust the angel to suit the slopping beam and sit it on top so it looks like it's cut...
or you can use sweep and set the profile to your beam profile...
HTH
Post edited on 2006-01-17 17:34:51
BEAMS JOINING COLUMNS problem |
Tue, Jun 30, 2015 at 7:41:51 AM
Joining Beams |
Tue, Feb 19, 2013 at 9:50:06 AM
joining two beams |
Fri, Jul 6, 2007 at 12:03:10 PM
Concrete beams joining at expansion joint |
Tue, Feb 8, 2011 at 2:04:44 PM
Concrete Beam Not Joining? |
Fri, Jul 15, 2011 at 10:59:14 AM
