7 Users Online (5 Members):
Forums >> Community >> Newbies >> Ignoring grid lines between independent structural systems
1 Posts No Rating |
I'm currently working on a project with two separate structural grids: one for an existing building and another for a new high-rise I'm designing on top of it. Due to the nature of the two buildings' interaction, both new and existing are within the same model. The problem is that when I place walls in the new building, the temporary dimensions measure to the nearest datum point. This is as often a grid line for the building below as it is to a nearby wall.
Is there a way I can tell Revit to ignore a set of grid lines? Or since the existing building columns will not be changing, am I better off deleting these grid lines and limiting the grids to the new construction? Any advice anyone may have would be helpful. Thanks.
Chris
Put the grids on two seperate worksets and turn off the unwanted for normal work.
Grid Lines - Instance based text in grid line family |
Mon, Jul 23, 2018 at 2:17:14 PM
how do you make structural beam systems visible. |
Fri, May 8, 2009 at 4:34:31 AM
grid lines extend beyond detail |
Mon, Jul 20, 2009 at 2:06:00 PM
Multiple bays of Framing for Structural |
Tue, Mar 30, 2010 at 6:45:10 PM
Manipulate Structural Grid in Architectural model |
Mon, Nov 14, 2011 at 4:11:47 PM
