Forums >> Revit Building >> Technical Support >> Leveling the topography in specific region
Thu, Nov 1, 2012 at 12:40:26 AM | Leveling the topography in specific region
billz1508work
Is there a way to level out the topography over a specific area. I have currently started a new project. In the early stages, modelling some masses up to do a walkthrough. I have a site of around 60,000sq m + and have to put around 8 warehouse distrubution centres on to. I have been given a rough masterplan by my architect.My major problem is developing the site around the warehouses. I need to have carparks which are pretty flat, and arn't just subregioned ontop of the topography (developed by a survey dwg in cad).. I also want to demonstrate kerbs and all. I used to previous just using a building pad to lower the carpark level, and use subregions to make kerbs exists etc etc, that was easi on a flat site. However as this is not flat, i need to know the following. - the best way to demonstrate a carpark in 3d, (give the impression it has real depth)- make the carpark a smoother gradient and then make it kinda merge back into the topography, so i dont have a massive difference and need to use retaining walls. i know i can click on individual points and adjust the levels, but this does not solve the issue of having grass at one height, kerb at the same, then a carpark 180mm lower. I'm sorry if not expressing myself in great clarity, though it's hard to put in words. In sketchup, it was a matter of pushing a pulling pretty much with some limitation. Any help, or references appreciated, thankyou.
Thu, Nov 1, 2012 at 6:00:39 PM | Leveling the topography in specific region
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
Sounds like a nice project. You might want to look into Site Works by Eaglepoint. See attached for my road work method. It is involved but produces a very nice and real looking result. Sometimes I create an additional topo within the topo.
Thu, Nov 1, 2012 at 11:46:33 PM | Leveling the topography in specific region
billz1508work
thankyou for your help mbsteve. I eventually just settled with building pads (flat and angled. Then i placed topopgraphy points where needed to make them join etc etc. I then subregions over subregion to make something look like kerb. lol. It has done the job for a concept proposal, however it does not have the lip running off to the road, like ur method has. Thankyou for your pdf, i'm going to try your method for the main street. Got to convince work to buy that siteworks, would had saved 2 days work atleast.
Topography - Cut and Fill for Graded Region
Fri, Feb 4, 2011 at 11:31:15 AM
Site plan visibility problem with graded region
Sat, Jan 8, 2011 at 12:57:02 PM
Topography Sub-Region accidentally deleted, how to get it back?
Wed, Dec 27, 2017 at 2:25:12 PM
Topography over multiple phases.
Tue, Jul 22, 2014 at 5:10:33 AM
Topography in elevations
Wed, Mar 4, 2009 at 4:23:06 AM
Page generation time: 5.5891
