Forums >> Revit Building >> Technical Support >> Revit MEP 2012 - How do I display hidden lines
Wed, Oct 31, 2012 at 8:56:01 PM | Revit MEP 2012 - How do I display hidden lines
bchester
Whenever I have the view style set to "Hidden Line", Revit masks the linework of families that are in close proximty to one another.  For example, if I place two electrical panels side by side, the adjacent edges disappear.  I could understand if the families were overlapping, but as it is, I have to keep 2"-4" between family components in order to avoid hidden lines. Is there any way to correct this behavior, other than making the familes transparent?
Thu, Nov 8, 2012 at 2:41:10 PM | Revit MEP 2012 - How do I display hidden lines
jlights
3 Stars: 2 Votes
Have you checked to make sure that Draw MEP Hidden Lines is checked in the Mechanical Settings dialog?
jlights
Displaying hidden lines in component families Revit 2010
Tue, Oct 6, 2009 at 7:21:47 AM
Symbolic Lines in Family - Display in Project
Fri, Jan 24, 2014 at 12:44:22 PM
Wall Hidden Lines and Object Styles
Tue, Jul 31, 2007 at 11:47:48 AM
Beam/Beam Intersections of Multiple Depths - Hidden lines?
Fri, Mar 23, 2007 at 1:23:59 PM
Changing display of walls below current level.
Wed, Jun 18, 2014 at 7:36:35 AM
Page generation time: 1.9595
