23 Users Online (21 Members):
Forums >> Revit Building >> Technical Support >> Revit 2013 Stair Glitch
2 Posts No Rating |
Hello-I sketched some stairs and they look great in plan view but very weird in 3D. I thought it might be a view plane or a cut plane with some interference but I can't figure it out. It renders through autodesk 360 the same way (with the glitch) so I've ruled out my graphics card. Help?Thanks
Hmm, not too sure, but if you look closely, you can see part of the landscape (well the white lines atleast) looking like they are raising over a bit of the stairs. try make a building bad under the stairs, and see if the problem still exists? just to rule out the landscape i guess. goodluck with it.
press vg, and make sure all imported or linked cad files are turned off
OLD problem with "Monolithic Stairs"....
Watch images attached to solve your problem...
2 Posts No Rating |
Thank you Typhoon!
56 Posts No Rating |
I've also noticed that there is a stair "run" setting for the bottom side of stairs, one slopes and one steps. On curved stairs I use the stepped run to avoid that problem. For some reason the slope bottom and curved stairs does just that.
Stair Rail Glitch |
Thu, May 7, 2015 at 7:35:59 PM
the promises of the new stair command in Revit Architecture 2013 |
Fri, Dec 14, 2012 at 9:17:29 AM
FYI. Stairs showing through floors in REVIT 2013 [ 1 2 ] |
Wed, Sep 23, 2015 at 2:57:56 AM
19
Create in-fill walls under spiral stairs - Revit Architecture 2013 specific |
Thu, Jul 7, 2016 at 10:50:48 AM
Stair break line problem |
Fri, Jul 17, 2020 at 4:21:45 PM
