Forums >> Revit Building >> Technical Support >> Revision schedules
Tue, Jan 17, 2006 at 12:24:03 PM | Revision schedules
davidr
I know Revit creates revisions schedules in the title block for you but is there a way to create a schedule that will list all the sheets that got tagged with a certain revision number? Also, clouds have a 'Comment' parameter where you can enter comments for the cloud-the revision associated with the cloud-how do you put this info into a schedule? The Revision schedules command seems to only pull info from the Revision settings setup dialog.
Tue, Jan 17, 2006 at 11:29:52 PM | RE: Revision schedules
eldados
eldados Avatar
4.5 Stars: 8 Votes
not that I'm aware of... but you can create a drawing list and add a field called Revision to it, you will need to change the number yourself, but it will be in a central location...
Integrator
KarelCAD
Revision Schedules in Revit 2014
Mon, Feb 10, 2014 at 11:15:58 AM
To set up Revision cloud schedule, and add prefix to Revision Number?
Sun, Jul 19, 2020 at 6:35:17 PM
View >> New >> Revision Schedule (GONE!)
Tue, Feb 20, 2007 at 11:48:28 AM
ADDING A FIELD TO REVISION SCHEDULES
Tue, Feb 24, 2009 at 11:19:41 AM
Hiding a Revision in the Revision Schedule
Thu, Nov 21, 2013 at 3:04:51 PM
Page generation time: 0.0753
