Forums >> Revit Building >> Technical Support >> Sloped railing along a wall
Fri, Oct 26, 2012 at 9:48:56 AM | Sloped railing along a wall
ossosso
Hi!
I've created a little wall that run all around the exterior of a building. It is a sloped wall (it means in some point I've edited the profile, or maybe attached it on top to a inclined reference plane). Now I'd like to put upon this wall a railing.
It seems a wall can't be taken like an hoste.. the only solution is to select each railing segment at time and specify for it "slope" with a certain height?
Thanks  a lot!
Sat, Oct 27, 2012 at 6:59:21 AM | Sloped railing along a wall
4 Stars: 205 Votes
You have to have Ramps or Stairs if you want your railing sloped... You have to approach this issue in a different way, maybe with "In-place" family OR "Adaptive component"
Railing on curved/sloped wall
Wed, Nov 21, 2018 at 12:06:53 AM
13
Sloped railing on sloped floor/ramp
Tue, Dec 9, 2008 at 9:25:00 PM
Curved railing.
Fri, Nov 15, 2019 at 11:36:39 AM
Add railing to existing stair
Tue, Oct 29, 2013 at 7:49:39 PM
Sloped railing on a Floor
Fri, Jul 2, 2010 at 11:32:10 AM
Page generation time: 2.0342
