Forums >> Revit Building >> Technical Support >> TAG the AREA of a REGION
Fri, Oct 26, 2012 at 7:13:47 AM | TAG the AREA of a REGION
zuzullo
I want to make a AREA TAG for Regions.
SEE LINK
How can I find that parameter?
Or do you know a family that already does it?
Do you wanna SKYPE Revit? Its quicker Smile
Sat, Oct 27, 2012 at 6:05:36 AM | TAG the AREA of a REGION
4 Stars: 205 Votes
Why don't you create an "Area Boundary" around your "Filled Region" then place the tag area?
Tue, Nov 20, 2012 at 1:12:29 AM | TAG the AREA of a REGION
Pavan
Pavan Avatar
4.5 Stars: 3 Votes
If the boundary is changed it will be rework if use area boundary. You can use 'Detail Item tag' which is in 'Annotations' folder. Add a shared parameter with name 'Area' and can manually enter the area from filled region property.
Pavan Reddy
Revit Manager
Intelligence is not always knowing the answers, it's always asking the questions.
Tag problem
Wed, Sep 13, 2006 at 3:47:54 AM
Area Tag issues
Tue, Dec 12, 2006 at 9:45:15 AM
tagging the surface area of a floor (revit2009)
Wed, Mar 3, 2010 at 11:14:36 AM
Room Tag vs Area tag
Tue, Aug 18, 2009 at 1:10:59 PM
Tagging 2 rooms with the same tag/area
Wed, Nov 20, 2013 at 8:11:44 PM
Page generation time: 0.3798
