Forums >> Revit Systems >> Technical Support >> Revit 2013 - Can't Use Align Tool on Edge of Curtainwall
Wed, Oct 24, 2012 at 10:35:10 PM | Revit 2013 - Can't Use Align Tool on Edge of Curtainwall
jpmays23
Hi all,
New to the forum, but not Revit.  I recently upgraded to 2013, and have found an issue that is driving me batty.  Say I draw a curtainwall, and I wish to move it by Aligning one Edge with something.  I select whatever reference edge, then try to click on my curtainwall to move it, but I cannot select the Edge!  Tab-clicking does not work, as it used to.  I can only select the centerline of the curtainwall.  Anybody experienced this, have a solution?  Thanks.
JP
Thu, Oct 25, 2012 at 6:53:22 AM | Revit 2013 - Can't Use Align Tool on Edge of Curtainwall
That is correct.  Align will only work with the CW location line.  You can contol the CW by using a mullion.
Revit defaults to the center of mullions as their CW location.  I believe in most cases, your mullions and panels should be set up on the exterior face.  That is a better control point.  If you don't choose to do that, you hav no choice but to use move instead of align.
Thu, Oct 25, 2012 at 7:16:05 PM | Revit 2013 - Can't Use Align Tool on Edge of Curtainwall
jpmays23
Is this a change from 2012?  It's been a few months since I used 2012, but I don't seem to remember this being a problem.  Why would AutoDesk decrease their functionality?
Fri, Oct 26, 2012 at 11:45:05 AM | Revit 2013 - Can't Use Align Tool on Edge of Curtainwall
No change - always been this way.
Curtainwall Ellipse
Tue, Feb 21, 2006 at 10:40:26 PM
coneptual massing curtainwall mullion issue
Thu, Nov 5, 2009 at 11:54:41 AM
Problem using 'paint tool' within copied groups - Revit 2013
Thu, May 23, 2013 at 6:36:47 AM
How do you make a canted or leaning curtainwall?
Wed, Jul 21, 2010 at 8:07:26 PM
Aligning Face of Curtainwall w/ Face of Wall
Tue, Mar 11, 2008 at 3:01:57 PM
Page generation time: 2.5898
