14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> dimension parallel to roof plane
57 Posts No Rating |
Hi all,
I have to measure a lot of instances of roof spans: dimensions aligned with/parallel to the roof planes (sloping), and measuring between roof/wall intersections. I can't get aligned dimensions to do the job, because they cannot select intersections of roofs and walls as a reference. Is there a way to do this without having to draw a lot of model lines as a work-around?
Thanks.
You need at least one perpindicular line to start with. I usually draw a symbollic line that is perpindicular tp hat I want to dimensin, then starting with that, I pick the interesections at each end then reselect the line to remove it. After finishing the dimension, I delete the symbollic line.
Thanks for that.
hmm still a bit of a work around. It is annoying to not be able to do this sort of dimension directly.
how to dimension a curved roof on a sloped plane |
Wed, Dec 24, 2008 at 6:15:21 AM
Lock/Dimension to intersections? |
Thu, Feb 1, 2007 at 8:35:46 AM
Dimensioning 2 non-parallel reference lines |
Thu, Feb 14, 2008 at 9:40:47 AM
Roof with non-parallel walls |
Tue, Feb 28, 2017 at 11:09:38 AM
Reference Plane Dimension |
Sat, Aug 20, 2005 at 7:33:46 PM
