Forums >> Revit Structure >> Technical Support >> Parametric Open Web Joist Family
Wed, Oct 24, 2012 at 12:11:51 PM | Parametric Open Web Joist Family
henrye88
Hi,
I am trying to create a parametric open web joist family, I have everything adjustable the way I want it, and have a parametric array dependent on length.  When the array formula functions such that there are extra web members beyond the chords, which are the length of the line I draw in the building project, the joist is built, but when I edit the formula so the web members stay within the chords and therefore the line I draw to make the joist, Revit says "Can't make type 18inchJoist.  Do any of you have ideas for how to fix this(keep web inside of chords and be buildable)?  Sorry if that description is confusing, I will upload the file and you can tinker with it and if you have any suggestions I would really appreciate it!
Wed, Oct 24, 2012 at 1:34:39 PM | Parametric Open Web Joist Family
henrye88
Nevermind, I got it to work.  Thanks anyways
Wed, Oct 24, 2012 at 3:46:30 PM | Parametric Open Web Joist Family
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
"Nevermind, I got it to work. Thanks anyways"
Insight on what you did to correct the error is always helpful.
open web steel joist
Wed, Sep 26, 2012 at 3:09:27 PM
Open Web Joist does not load
Mon, Feb 20, 2012 at 4:59:59 PM
Joist-modify-Can't make type K-Series Bar Joist-Angle Web : 22K6
Thu, May 22, 2008 at 9:48:50 AM
Attaching open web trusses to a sloped beam
Wed, Jun 20, 2012 at 5:15:07 PM
can't Make Type Joist error
Sat, Jun 28, 2014 at 8:00:53 PM
Page generation time: 1.6886
