Forums >> Revit Building >> Technical Support >> Printing PDF Line Drawing - Wont show surface textures
Tue, Oct 23, 2012 at 8:41:32 AM | Printing PDF Line Drawing - Wont show surface textures
Cleo77
Hi All,I have a problem. I am trying to print a perspective view into a PDF in hidden line view.I have a brick wall and a slate roof, neither of the pattern details are showing up in the PDF Print and I can't seem to work out why....If I zoom in further then you can start to see the brick and it will then print the pattern in the PDF However, I need a zoomed out version and I don't feel I am too far away that shouldn't be able to see the bricks if you get me.Could some please advise me as I can't seem to find a forum with the answer.Cleo77
Tue, Oct 23, 2012 at 9:24:39 AM | Printing PDF Line Drawing - Wont show surface textures
This is often the case when the pattern gets too small to print.  You might try a different pdf printer but I doubt that will do it.
You could also scale your view up then if printing the PDF, print to a scaled size.
Revit 2013 textures not printing to pdf or paper
Mon, Feb 3, 2014 at 2:15:52 PM
Printing
Tue, Oct 5, 2010 at 6:38:41 PM
3D PDF inclusive material textures
Tue, Jun 25, 2013 at 2:28:04 PM
problem printing line weight to pdf
Tue, Sep 30, 2014 at 3:31:49 PM
Black lines printing grayscale in PDF
Fri, Oct 10, 2014 at 4:46:46 PM
Page generation time: 0.9207
