Forums >> Revit Building >> Technical Support >> Wall Fill Pattern question
Tue, Oct 23, 2012 at 7:51:18 AM | Wall Fill Pattern question
lizardman2124
Is there a way to do wall fill patterns and force them to be a certain width?  I am working on life safety plans and want to use wall fill patterns, but I have specialty wall thicknesses that the fill pattern cannot be seen when printed because the wall is too thin. My company would like for all fire rated walls to be the same thickness regardless of how thin or thick the wall is.  Is this possible when using fill patterns?
Tue, Oct 23, 2012 at 7:55:11 AM | Wall Fill Pattern question
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Do a search for fire rated walls and there are a lot of threads here on th subject.
Tue, Oct 23, 2012 at 8:39:37 AM | Wall Fill Pattern question
I believe that you will find that wall fills will not be your answer.  They will be only the thickness of the wall.
We prefer to halftone the model elements and add wide linework (different for each rating) down the center of our rated walls.
Not parametric but easily read.
Fill Pattern not show up when print
Wed, Apr 25, 2012 at 4:08:55 AM
Scaling fill pattern
Thu, Nov 17, 2011 at 4:01:24 PM
color scheme/fill pattern
Mon, Jul 9, 2012 at 4:56:36 AM
EDITTING FILL PATTERNS
Fri, Dec 9, 2005 at 6:51:29 PM
Revit Detail Level fill pattern, Texts in Elevation and Section's Symbols
Mon, Jul 30, 2012 at 7:12:54 AM
Page generation time: 3.4644
