9 Users Online (7 Members):
Forums >> Revit Building >> Technical Support >> phasing
38 Posts No Rating |
Revit 2013
I have recieved a plan from an architect that is all in one phase when our building requires phasing-years of contruction/additons. When it is already completed without phasing how do I speparate the building into phases. When I highlight area the properties panel does not give me this option for all items only some.
I hope that's clear. Thanks.
You have to establish the phase first.
Really? with all this program does ....the drawing can't be re-phased to suit the new plan owner's needs??
Did you read my answer?
I said the phase has to be created first. You can't assign anything to a phase that doesn't exist. Revit just can't read your mind.
It read to me that the phasing had to br created first ie: beginning of the project ie: no turning back. Apologies if my answer was taken wrongly....clealy was.
I have created all the phases required....I have used phasing quite a bit.
Phasing does not have to be created at the being of a project. It can be Phased anytime.
Thank you.
I have a building that has been created under one phase (existing). Each wing of this school was built in different years and I was looking for an easy way to place those additions in the appropriate phases that I have already created. I have highlighted the area and using the properties window chosen each element to change their phase however some elements do not allow me to do this.
I have carried on and done it manually so to speak....doing each item as allowed. I had hope there was an easier way that I wasn't figuring out on my own because the program does so many things with little effort that this did not seem consistent.
Please forward to WWhub.
Phasing - Building Already Done but Dind't Set up Phasing |
Tue, Dec 15, 2009 at 7:40:42 AM
Phasing moved to Visibilty/Graphic |
Wed, Nov 18, 2009 at 4:11:56 PM
Wall and Instance phasing warning - Incorrectly Reporting? |
Thu, Oct 11, 2018 at 3:37:00 PM
PHASING |
Tue, May 20, 2008 at 1:57:25 PM
Maintain phasing when copying elements - how? |
Tue, Mar 10, 2009 at 10:02:08 PM
