Forums >> Community >> Newbies >> Colouring Casework form Revit Library
Sun, Oct 21, 2012 at 2:16:53 AM | Colouring Casework form Revit Library
Kim17
Greetings, I am new to RevitCity and the language. I work on the KISS principle (Keep It Simple S.....)
Was hoping to get some info re: Casework from Revit library. I have used kitchen cabinets in a project and want to render (?) colour them. I have tried editing the cabinets in Materials properties with no luck... also tried filled region and paint again no luck.
Also can anyone explain what rendering is???? Is it colouring in, adding texture & the ability to change materials or something more complex???
Can anyone out there help!! please
Thanks Kim17
Sun, Oct 21, 2012 at 6:04:31 AM | Colouring Casework form Revit Library
4 Stars: 205 Votes
You should read your HELP: http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/1468-Document1468/2034-Renderin2034
Edited on: Sun, Oct 21, 2012 at 6:05:22 AM
Tue, Oct 23, 2012 at 7:10:50 AM | Colouring Casework form Revit Library
Kim17
Thank you Typhoon.
Kim
Casework below countertop not visible.
Wed, Jan 27, 2010 at 2:16:58 PM
REVIT 2015-HOW TO SHOW MODEL LINE ABOVE CASEWORK
Fri, May 1, 2015 at 11:17:57 AM
Colouring of Generic Model Patern Based Wall
Thu, Jan 12, 2017 at 12:24:32 PM
11
Phantom Casework
Tue, Aug 28, 2012 at 12:25:48 PM
Can you apply divide surface to a revolved form?
Wed, Jun 12, 2013 at 3:46:54 AM
Page generation time: 1.7977
