Forums >> Revit Building >> Technical Support >> Revit 2013 - Cut Wall under stairs.
Thu, Oct 18, 2012 at 3:06:23 AM | Revit 2013 - Cut Wall under stairs.
ossosso
Hi!
Please take a lookt to the attachment. You can see a stairs which intersect a wall. I'd like the wall to be cut by the stairs which goes up.
Which method? Thank you.
Thu, Oct 18, 2012 at 3:23:10 AM | Revit 2013 - Cut Wall under stairs.
4 Stars: 205 Votes
2 ways:
1º Create a section view in that stair, create a "ref. plane" under the stair, attach the wall to that ref. plane.
2º Create a section view in that stair, select the wall and "edit profile", sketch the new shape of that wall under the stair.
Edited on: Thu, Oct 18, 2012 at 3:25:53 AM
Stairs and plan regions (cut height)
Mon, Apr 21, 2014 at 10:22:57 AM
FYI. Stairs showing through floors in REVIT 2013 [ 1 2 ]
Wed, Sep 23, 2015 at 2:57:56 AM
19
Revit 2013 Stairs/Handrails
Thu, Feb 14, 2013 at 7:27:18 PM
Can't create monolithic stairs (Revit 2013, beginner)
Fri, May 27, 2016 at 11:21:56 AM
Create in-fill walls under spiral stairs - Revit Architecture 2013 specific
Thu, Jul 7, 2016 at 10:50:48 AM
Page generation time: 4.4492
