Forums >> Revit Building >> Technical Support >> Adding Doors
Wed, Oct 17, 2012 at 12:05:45 PM | Adding Doors
sakalaukus
I am a newbie to Revit.  For some reason, surely usere error, I am getting a no symbol when attempting to add doors or windows.  I've attached the file.  Any tips or suggestions would be very much appreciated!
Wed, Oct 17, 2012 at 12:22:22 PM | Adding Doors
fastjohnnyz
Do you mean door and door swing symbol? Or the symbol for taggin the door (i.e. 101, 202)? If it is the tag symbol for the door, make sure the "tag on placement" is highlighted. If it is the door and door swing, check your visibility graphics to make sure it is turned on. Also make sure you are in a floor plan. Or check your view range.
Wed, Oct 17, 2012 at 12:53:29 PM | Adding Doors
sakalaukus
The visibility for doors is ON.  I think I am not in floor plan view.  How do I get back there?
To answer your question, the doors themselves are not able to be placed b/c I am getting a NO symbol.
Thanks for the quick reply.
Wed, Oct 17, 2012 at 1:01:15 PM | Adding Doors
The number symbol does not have to be visible to place the doors.  And if you want to see it, it has to be turned on under VG/Annotations.
dOORS AND DOOR SCHEDULES
Mon, Aug 6, 2007 at 11:28:15 AM
Base Cabinets, stretching and adding doors
Tue, Jul 29, 2008 at 7:55:42 PM
Scheduling from linked files adding comments
Mon, Feb 22, 2016 at 11:06:44 AM
Adding the solar heat gain coefficient to glass doors?
Mon, Dec 16, 2013 at 5:08:27 AM
Adding options in the properties for doors
Tue, Sep 6, 2011 at 7:46:17 AM
Page generation time: 2.3301
