12 Users Online (10 Members):
Forums >> Community >> The Studio >> How do you make a Dutch Hip Roof with roof modeler?
I can do it with seperate roof models but I get a line at the intersection. Is there no way to do this with the roof modeler?
In sketch mode, select the roof edge you want to dutch hip, go to properties and use the "Offset From Roof Base" Parameter.
Post edited on 2006-01-16 18:54:55
Would't let me edit this jpg into the last post so here it is.
Post edited on 2006-01-16 19:01:34
I designed my studio-workshop-garage a few years ago with a dutch hip.
This one uses three Revit roofs.
I'm attaching a zip file that has 2D DWF views of the elevations and plans.
there is also one 3D DWF so you can look at the roof in 3D...you will need the free DWF installed on your system to view
I use Reference planes in the plans and elevations to help layout the roof sketches.
In this example I create a hip roof on level one for tracing purposes. The final roof is on level 2.
Once one end of the roof is completed, I will mirror to the other end of the building.
It took me about 8-10 minutes to complete this from scratch.
Consider using the ALIGN command to make sure all of your surfaces blend to gether as you connectthe 3 roofs.
Cheers!
LinkedIn Profile:
- http://www.linkedin.com/in/danielhughes1/
I author Bradley BIM Blog: http://bradleybim.com |
"Dutch Gable" roof |
Mon, Mar 31, 2008 at 1:35:54 PM
Roof - adding smaller gable to dutch hip. |
Tue, Oct 28, 2008 at 11:32:20 AM
dutch gable in roof |
Tue, May 29, 2007 at 11:28:04 PM
Partial Hip Roof |
Tue, Jun 26, 2007 at 3:22:10 PM
how to cut a hip roof in revit. how to attach a small roof to a big roof |
Fri, Feb 11, 2011 at 1:16:54 PM
