Forums >> Revit Building >> Technical Support >> copy in family killing parameters.
Wed, Oct 17, 2012 at 8:23:52 AM | copy in family killing parameters.
JRPcad
Hi all,
I'm trying to create a coffe mug family, I'm struggling a little with 2 particular areas:
1. I've been trying to create a void that cuts the handle. The logical thing for me to do was to create a copy of the actual mug body, edit the revolve to simplify it turn it into a void then cut the handle. However, as soon as I create a copy of the mug body the radius and depth parameters stop working (they worked perfectly before copying) Any ideas on this, or why it's happening???
2. I wanted extra shape around the mug handle where it joins the mug, currently i'm using a swept blend with a spline as the path. I was hoping there was a way that I cold add a 3rd profile somewhere along the path, similar to what you can do in mass modelling. If anyone knows a way of doing this Id really love to know, that way I will be able to keep the handle organic and clean (I tried sticking 2 splines together but it looked messy around the join as it's very hard to keep a continuous curve)
Any help on either problem will be appreciated - I've attached the file
Edited on: Wed, Oct 17, 2012 at 8:24:14 AM
For Architectural Services visit www.jrpcad.co.uk
Glulam Family Parameters
Tue, Sep 24, 2013 at 9:16:34 AM
Create a family that includes another family
Tue, Oct 11, 2022 at 12:32:18 PM
Cant edit family parameters?
Wed, Jul 15, 2009 at 1:36:26 AM
Corrupt Elements Are killing US
Wed, Aug 22, 2007 at 12:35:38 PM
Door family - how to delete unwanted parameters
Tue, Feb 7, 2006 at 3:25:01 AM
Page generation time: 0.8174
