Forums >> Revit Building >> Technical Support >> Project North
Tue, Oct 16, 2012 at 11:13:03 AM | Project North
Ellie02
Revit MEP 2013
I have a project that is at an angle.
I have rotated the Project North before I begin working with the model.
Please could you confirm if I am correct in stating that this will rotate only my plan views and not the actual 3D view?
I am assuming that true north is there for the task of keeping the model at the same rotation to allow collaboration with other disciplines. M&E, Arch, Structural etc.
Thanks
Tue, Oct 16, 2012 at 12:16:40 PM | Project North
True North is just that.  Solar studies, shadows and property lines using bearings will all be correct.  Project North does set all views up according to your rotation.  But always remember, you can independently rotate any view.
Tue, Oct 16, 2012 at 3:25:51 PM | Project North
Ellie02
So I can adjust project North as I see fit at the beginning of my project with any concern for collaboration issues as this is only relevant for the true north. Are there any other considerations I should be thinking about? I've chosen this way as I'd pretty much like all views to be that rotation. Is it the best solution? Thank you Smile
Tue, Oct 16, 2012 at 3:48:57 PM | Project North
Project north is always the best solution rather than rotating each and every view.
Collaboration is a different issue and very hard for most new users to understand.  I suggest you read as much as you can about defining the project's location and how that relates to other consultants in both Revit and CAD.
rotate PROJECT north (not true north)
Wed, Jun 10, 2009 at 9:11:40 AM
True North vs Project North Linked dwgs
Thu, Mar 10, 2016 at 10:02:26 AM
Spot Coordinate - True north vs project north
Tue, Oct 22, 2013 at 4:42:05 PM
How to Rotate True North without rotating the whole Project?
Thu, Mar 18, 2010 at 7:25:35 PM
project north/true north
Thu, Mar 17, 2005 at 5:00:19 PM
Page generation time: 3.1855
