Forums >> Revit Building >> Technical Support >> Pile cut-off Level, Adding Parameter to Pile Family ??????
Tue, Oct 16, 2012 at 10:06:49 AM | Pile cut-off Level, Adding Parameter to Pile Family ??????
kathey1
Can anybody help me with this pile cut-off question. I want to add the pile cut-off to a schedule but i dont know how to do it. Ive been told that all i need to do is ''add the start and end elevation column in the schedule using parameters'' but im not sure how to go about it ?
Can anybody help me ?
Ive got a feeling that i would need to add a parameter to the pile family so that the schedule picks it up but im not sure.
Any help would be much appreciated.
Thank you
Tue, Oct 16, 2012 at 12:21:54 PM | Pile cut-off Level, Adding Parameter to Pile Family ??????
If the parameter controls the family, then yes, you would have to add it to the family.  If it is just a value, then you can add it as a schedule parameter from within the schedule.
Tue, Oct 16, 2012 at 1:34:30 PM | Pile cut-off Level, Adding Parameter to Pile Family ??????
kathey1
I've added a shared parameter in the family (pile Cut-Off. See attachment) but all it shows in the schedule is the dimension (150). When I place the pile cap in my project I want it to show me the level which it is at.
Ive not a clue how to go about it ! Hmmmm ??
Tue, Oct 16, 2012 at 2:39:10 PM | Pile cut-off Level, Adding Parameter to Pile Family ??????
If that is a level and it hosts your family, then you could get it as a name (not a value).  Otherwise I don't think you can do that.
Pile Cap Hidden Line Issues
Wed, Apr 20, 2011 at 9:31:16 AM
Pile Cut off in Schedule
Mon, Oct 8, 2012 at 2:40:03 PM
Pile cap issue
Thu, Jun 3, 2010 at 7:22:27 AM
Elevation parameter in pile-schedule
Tue, Feb 19, 2013 at 4:28:38 AM
Snazzy Pile Cap Family
Wed, Aug 27, 2014 at 2:35:17 PM
Page generation time: 0.8986
