Forums >> Revit Building >> Technical Support >> nested family
Mon, Jan 16, 2006 at 6:42:58 AM | nested family
Bhawani
I am new to Revit,please help how to do nested family & parametric. thank u
Mon, Jan 16, 2006 at 11:58:17 AM | RE: nested family
TomDorner
4.5 Stars: 25 Votes
Check out Mr. Spot's tutorial on this subject: http://www.revitcity.com/tutorials/arrays_and_nested/ Tom
Fri, Aug 22, 2008 at 10:30:18 AM | nested family
Luminosa
Great tutorial.  I'm having a problem, though.  (In my case I'm working with doors - trying to nest a door panel component into a frame family).
When I go to place the door panel in the frame family, it only lets me move the panel left to right, instead to toward the front or back of the wall (I need to dimension in the latter direction), despite the fact that I've set the Left vertical reference to Defines Origin in both the component and the family.  It keeps placing the door panel component in relation to the center of the wall in the Frame family, and only lets me move it left to right...
What am I doing wrong?  I would really appreciate any help with this - I'm so close to making use of the powerful nested family - I can't fail now!!!
Fri, Aug 22, 2008 at 10:58:45 AM | nested family
Luminosa
Well, I didn't figure out how to change the origin of my door panel made from a door template (wall-based), but I did find a work-around:  I remade my panel from a generic family template and then nested it into my frame family (made from a door template, wall-based), and now I have the freedom to move the panel in any direction within the frame family.
Fri, Aug 22, 2008 at 11:03:42 AM | nested family
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
Your second method is actually the prefered method. Any time you need to make a component for a nested family, start with a generic model family and just change the category to the particular family type you need.
As for your other; this was probably caused from having the "panel" associated with a work plane. I believe it will do this automatically.
nested family rotation
Tue, Sep 3, 2013 at 1:25:41 PM
scale nested family within a family (2017)
Wed, May 3, 2017 at 5:28:43 PM
Nested Family Count in Table
Mon, Jan 15, 2018 at 11:47:52 AM
Locking nested families?
Wed, Aug 27, 2008 at 12:23:09 PM
13
Nested family always vertical?
Mon, May 16, 2011 at 2:55:02 PM
Page generation time: 0.5500
