Forums >> Revit Systems >> Technical Support >> Rendering in Revit
Mon, Oct 15, 2012 at 9:05:05 AM | Rendering in Revit
StuartHide
I am having issues with fat (ish) black lines on the revit perspectives I have recently generated on a job (see attached)- would you have any tips on this?  It is curious that the standard isometric 3d view prints with such a better line quality.
Any help would be greatly appreciated
Mon, Oct 15, 2012 at 9:08:11 AM | Rendering in Revit
DevonK
4 Stars: 5 Votes
Do you have the thin lines on. If not, you might turn them on and they wont show up so fat.
Mon, Oct 15, 2012 at 9:16:03 AM | Rendering in Revit
StuartHide
Is it recommended to turn thin lines on for rendering
Mon, Oct 15, 2012 at 9:21:39 AM | Rendering in Revit
DevonK
4 Stars: 5 Votes
I usually do for that reason specifically and know many others that do the same. Try that and see if that helps at all.
Mon, Oct 15, 2012 at 9:38:53 AM | Rendering in Revit
StuartHide
Many thanks I will try this and let you know if successful.
Thank you for such a quick responce.
Mon, Oct 15, 2012 at 9:57:34 AM | Rendering in Revit
DevonK
4 Stars: 5 Votes
No problem
Mon, Oct 15, 2012 at 5:03:27 PM | Rendering in Revit
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
if thats just a typical 3d view you can change the scale and the lineweights will change. if its an actual physical camera view you can to: Graphic Dispay Options - Model Display - Silhouettes
here you change the silhouettes to a thin lines or 1 linetype. however you have them created.
Tue, Oct 16, 2012 at 1:41:39 PM | Rendering in Revit
saggynutsack
3 Stars: 2 Votes
You need to go into autodesk revit and create a new render, if you can divide the recipocal by the dominator. Obivously you guys are new to this and have no idea what you are talking about lmao. you can then take you rendered prjoect and put it into microsoft word.
revit rendering
Thu, Oct 14, 2010 at 8:33:24 AM
Revit MEP 2009 Rendering
Thu, Mar 5, 2009 at 8:35:55 PM
What is the best revit/rendering engine combo? [ 1 2 3 ]
Tue, Feb 3, 2015 at 9:40:52 AM
31
Revit 2009 Rendering Problem(Black screen) [ 1 2 ]
Mon, Apr 1, 2013 at 2:45:28 PM
27
Realistic Rendering [ 1 2 ]
Thu, Aug 4, 2011 at 2:30:37 PM
25
Page generation time: 2.7905
