Forums >> General Discussion >> Wishlist >> concrete column
Mon, Oct 15, 2012 at 8:51:09 AM | concrete column
garchinski
I am loooking for a concrete column that will be multi storey & that you can manipulate the column size for each level. (ie. 500X500 from main to seconf, 450X450 from 2nd to 3rd, 400X400 from 3rd to roof)
Mon, Oct 15, 2012 at 9:06:44 AM | concrete column
You will need a seperate column for each level.
The easy way to place these is one level, then copy all to clipboard, paste aligned to next level and while still chosen, change their size then do the ame to the next level....
Mon, Oct 15, 2012 at 9:19:47 AM | concrete column
garchinski
thanks for the quick reply!
Concrete pad footing moves with steel column
Thu, Dec 12, 2013 at 10:58:07 PM
Auto Join Concrete Column & Beams
Thu, Jul 1, 2010 at 2:08:30 AM
Concrete Frame - Elevation View
Fri, Mar 4, 2011 at 9:28:06 AM
Flushed Wall & Column
Thu, Sep 6, 2007 at 11:19:18 AM
stacked structural concrete columns
Wed, Apr 4, 2018 at 9:49:51 AM
Page generation time: 0.6695
