22 Users Online (20 Members):
Forums >> Revit Building >> Technical Support >> Grid Labels not visible while drawing a grid
6 Posts No Rating |
Hi.
when ever i start a new project i draw its grid - but when im doing it its labels arre not visible for example A,B,C.... and 1,2,3....
anyone can help?
type VG - then in the annotation tab, turn grids on.
If it is just the grid bubble that is not showing you need to change it in the type editor, if a grid bubble is not loaded you need to load one first.
6 Posts No Rating |
nope not working - probably im not explaining properly.
let me attach an image - thanks btw
6 Posts No Rating |
teafoe - its the grid bubble. can u explain that a bit please.
It appears that you are not using the standard grid head, otherwise the column line would be at the center of the bubbles. Therefore, the problem is probably your grid head family and we don't know what you did.
WWHub is correct. Try using an out of the box grid bubble and see if that solves your problem. Then look into how to fix your custom grid bubble.
6 Posts No Rating |
ookay - thanks alot guys - ill try that
basically its just my second day with revit and trying to work with revit since 2 years now but its kind of scary. but this time im not gonna quit. thanks alot - thats a great help
MOVE GRID LABELS ON ONLY ONE DRAWING |
Sat, Jul 12, 2014 at 1:56:41 PM
2'x2' Diemsional Grid |
Wed, Feb 5, 2014 at 2:10:47 PM
Grid Partial Visibility |
Wed, Aug 3, 2016 at 1:08:39 PM
GRID AND SECTION VISIBILITY |
Thu, Dec 20, 2007 at 8:03:27 PM
disappearing grid lines |
Wed, Apr 19, 2006 at 5:44:48 PM
