Forums >> General Discussion >> Revit Project Management >> Truss family
Sun, Oct 14, 2012 at 12:25:43 AM | Truss family
arch87
Hi guys i have created a Truss family using the generic template, the problem is i could not edit the dimension on the properties i want the length to be shorter but i cant click on it or activiate the length on the dimension tool.
the idear is to create a truss that i can keep on changing it whenever i want without re drawing other family to suit my current space?
hope this make sence and thank you in advance for your help
Tue, Oct 16, 2012 at 11:52:24 AM | Truss family
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Attaching your family will be more helpful to be able to answer.
Tue, Oct 16, 2012 at 12:26:44 PM | Truss family
It sounds like you do not understand parameters.  I suggest you download the families guide from the autodesk site.  It will teach you so much that you really should know.
Tue, Oct 16, 2012 at 7:20:05 PM | Truss family
arch87
Hi guys thanks for the reply i managed to fix it all i did is just click edit type under properties which there the dimension tool was active for editing the truss dimensions
thanks again
Truss overhang help
Wed, May 23, 2012 at 8:32:23 AM
Problem with Truss Family
Fri, Sep 25, 2009 at 7:34:32 AM
Truss steel system family creation
Mon, Oct 19, 2009 at 4:27:52 PM
TRUSS FAMILY diagonal webs
Thu, Mar 8, 2012 at 11:26:51 AM
Truss Family
Thu, May 2, 2019 at 4:54:47 AM
Page generation time: 0.6595
