Forums >> Revit Building >> Technical Support >> Problem with adding a material to this bathtub
Fri, Oct 12, 2012 at 11:34:42 AM | Problem with adding a material to this bathtub
SooRabid
How would i add a material to this bath tub in revit 2013? For some reason it does not give me the option and i can not add materials by going into the family.
http://www.revitcity.com/downloads.php?action=view&object_id=1245
Fri, Oct 12, 2012 at 12:07:53 PM | Problem with adding a material to this bathtub
If the elements in the family are Revit, then materials are initially controlled by assignment in the family per individual element.  If the elements are CAD imports then they too are controlled in the family initially by assignment to the CAD layers.
NOTE the term INITIALLY.... Once any item is loaded into a project, the materials are loaded as well.  That means if the material in the family was called tub and colored as blue and it is redefined as tub colored red, it will be red in new projects but any it was already loaded into will be blue.
^^ Read and re-read this.  THE PROJECT RULES!
Fri, Oct 12, 2012 at 12:44:03 PM | Problem with adding a material to this bathtub
SooRabid
so the only way for me to change the materials is to have the initial file?
Fri, Oct 12, 2012 at 1:06:41 PM | Problem with adding a material to this bathtub
I did not say that.....
If the family is loaded then so is the material.... so if the material is now in the project, it has to be changed there ... or deleted and the material changed in the family and the family reloaded.
Think about this.  You should design all families with an initial material that is well named so that it can be controlled in the project.   After all, not all projects are the same - so this is why the PROJECT RULES.
Adding Material to Families based on Cad Imports
Tue, Jun 23, 2009 at 11:37:00 AM
Adding Special Symbol
Sun, Feb 5, 2006 at 10:13:33 AM
Adding a new material in Revit 2013
Mon, Jul 29, 2013 at 4:32:34 AM
adding a material to and object and it does not layout right???
Mon, Jun 27, 2011 at 7:15:41 PM
adding material to a dxf object
Wed, Nov 9, 2005 at 11:13:34 PM
Page generation time: 1.3243
