Forums >> Revit Structure >> Technical Support >> pivot point of compass view cube
Fri, Oct 12, 2012 at 10:23:49 AM | pivot point of compass view cube
937delta
I am working on a model which has a small building located within a site. The view area is mostly taken up with a .dwg file in the back ground. The only way I seem to 'temporarly' move the pivot point is to zoom far out within 3d view of the model, I can select a roof or wall of the small building and if I spin the compass the pivot point will move to the centre of this element and thus the whole model will rotate about this point. This would be how I would move the pivot point. However I am very far out and want to spin this model about this point close up. However when I start to zoom in there is a point were the pivot point resorts back to the centre of the main model. As usual with Revit each little simple problem can take dayyysss to work out! Anybody come across this before?
Fri, Oct 12, 2012 at 10:41:03 AM | pivot point of compass view cube
Imported DWG files can cause problems like this.   Do you really need it on?  Did you put it in a seperate workset so it is easily turned on and OFF?  Do you know how to use a scope box?
Fri, Oct 12, 2012 at 10:59:33 AM | pivot point of compass view cube
937delta
Should I have just linked the drawing rather than importing it? I will try a scope box - Thanks
Fri, Oct 12, 2012 at 11:14:11 AM | pivot point of compass view cube
I should not have limited it to imported.... it is all DWG files that are too large.  I recommend that you always put imports and links in seperate worksets so they can easily be controlled.
BTW - You can do the worksets anytime.
How to pivot about centroid of model?
Wed, Feb 4, 2009 at 3:54:27 PM
11
Memory Issue? Elevation view from view cube
Tue, Mar 8, 2016 at 3:16:45 PM
view cube in wrong position
Fri, Jan 30, 2015 at 10:28:20 AM
Linking 3D Dwg files from AutoCAD Architecture to Revit MEP
Thu, Aug 26, 2010 at 7:14:12 AM
Revit 2015 Curtain Wall-Offset Pivot-Single Door
Thu, Aug 6, 2015 at 11:32:27 AM
Page generation time: 3.1482
