Forums >> Revit Building >> Technical Support >> 'Activate View' on sheets
Fri, Oct 12, 2012 at 5:23:18 AM | 'Activate View' on sheets
MEBDesign
Question regarding the 'Activate View' option when highlighting views on a sheet. Once you have activated a view, made your changes or whatever, how do you exit the activated view? No matter what I do I can't seem to. End up having to open some other views then go back. Am I missing something simple?
Thanks
Fri, Oct 12, 2012 at 7:18:28 AM | 'Activate View' on sheets
Right click - deactivate view.  You have to be in the view on that sheet.
Fri, Oct 12, 2012 at 7:39:42 AM | 'Activate View' on sheets
MEBDesign
Aha! Knew it would be something simple. Thanks!
Tue, May 7, 2013 at 11:26:56 AM | 'Activate View' on sheets
jereisluke1980
I have been wondering about this for a while.  For me, I would just ignore it and eventually Revit would get out of the view if I started going to other sheets and working on them.  I kept looking for a button before, as Revit uses buttons for so many other commands.
Sheet 'X' of 'Total Number of Sheets'
Wed, Jun 5, 2013 at 4:39:34 PM
Sheet # of 'total number of sheets'
Fri, Nov 16, 2007 at 6:59:54 AM
Titleblock issues: Can't 'activate' the labels I created...
Mon, Jan 24, 2011 at 3:49:27 PM
View Labels and Bubbles are gone?
Mon, Jan 23, 2006 at 12:16:57 PM
Using standardized detail sheets
Tue, Apr 18, 2006 at 8:43:19 AM
Page generation time: 0.8038
