Forums >> Revit Building >> Technical Support >> Revit 2012 stretch arcs
Thu, Oct 11, 2012 at 12:31:31 PM | Revit 2012 stretch arcs
Revit548
I seem to be having trouble manipulating the arc detail line. After the arc is drawn, I cannot move just one of the endpoints, it moves the arc down the same curviture but not left or right, or it moves the entire arc at once. Is there a way to just move one end of the arc without moving the center or the other end.
Thank you
Thu, Oct 11, 2012 at 12:53:49 PM | Revit 2012 stretch arcs
Don't use the move command.  Click on the arc, then pull around the blue dot at the end.
Thu, Oct 11, 2012 at 1:36:48 PM | Revit 2012 stretch arcs
Revit548
I don't use the move command, I highlight the arc and grab the point at the end, but it just allows me to move along the radius of the arc, but not anywhere else without moving the entire arc. Any suggestions?
Thanks
Thu, Oct 11, 2012 at 1:40:09 PM | Revit 2012 stretch arcs
I don't understand.  It is an arc!  Either uou move the arc or stretch it aroud according to its radius.  What else would you expect?
Thu, Oct 11, 2012 at 1:40:24 PM | Revit 2012 stretch arcs
Revit548
Thanks
Thu, Oct 11, 2012 at 1:42:19 PM | Revit 2012 stretch arcs
Revit548
I'm looking for a way to stretch the arc, even if after streching the arc it isn't really an arc anymore, as long as it it still joined with the device on the other end.
Thu, Oct 11, 2012 at 1:43:56 PM | Revit 2012 stretch arcs
4 Stars: 205 Votes
No, but on Ribbon uncheck "Keep Concentric" then you can grab the middle point of arc and move ONLY that point.
Thu, Oct 11, 2012 at 1:48:19 PM | Revit 2012 stretch arcs
Revit548
That's a bit tougher than how autocad does it but that works. Thanks for the help
Thu, Oct 11, 2012 at 1:49:34 PM | Revit 2012 stretch arcs
4 Stars: 205 Votes
Sorry but REVIT is not AUTOCAD, thank God....
"stretch" command?????
Wed, Apr 5, 2017 at 3:38:58 PM
Can you define patterns using arcs?
Sun, Apr 30, 2006 at 7:23:27 PM
parametric fillet arcs on profiles
Fri, Oct 19, 2007 at 12:20:40 PM
Stretch Length of family
Tue, Nov 14, 2017 at 3:58:50 PM
"Stretch" in MEP 2012
Mon, Jun 4, 2012 at 11:29:35 AM
Page generation time: 1.8793
