17 Users Online (15 Members):
Forums >> Revit Building >> Technical Support >> removing grid lines from curtain
So i have looked but cant find this simple answer. I dont use curtain walls much but need to complete the store front.
how do you remove the curtain grid line? I get no options for that I can find.
Also, where are the options to change the size of the mullions. I select one and the types are all greyed out.
To remove the grid lines, click on one and on the ribbon you will see a add/remove segment. Click on that and then click on
the segments you want to remove. To change the mullion size, highlight--> edit type
Or you select the mullion and unpin it, then you will no longer be grayed out.
OMG DUh! Locks!! thanks, I was crumbling!
Haha, no problem. We have all been there a time or two.
Curtain Grid Removing Segments |
Mon, Jul 2, 2007 at 1:05:12 PM
Curtain Grid Problems [ 1 2 ] |
Wed, Apr 10, 2013 at 5:57:45 AM
19
Revit 2013 Curtain Wall Variable Grid Spacing |
Thu, Jul 18, 2013 at 2:10:54 AM
Removing multiple curtain wall grid segments |
Mon, Jun 13, 2016 at 9:53:15 PM
Curtain Wall Grid Lines |
Tue, Sep 3, 2013 at 4:56:10 AM
