Forums >> Revit Building >> Technical Support >> Can't copy Lights - "Can't place inserts outside of hosts. !
Thu, Oct 11, 2012 at 6:32:37 AM | Can't copy Lights - "Can't place inserts outside of hosts. !
leedeetee
Hi all,
Just wondering if you can help as I’m pulling (what’s left of) my hair out ….  I've attended the Essentials, Advanced and Family Creation Autodesk courses but I'm now on my own ... !
I’ve started to model a 'module' of a building I am working on.
I would like to be able to copy the lights and then subsequently the modules so I can easily create larger buildings. However, I keep getting an error message - Can't cut instance(s) of Cabin Light out of its host.
Can you help at all?! I've tried everything I can think of and would REALLY appreciate it.
I would attach a file but even when I trim it down to just a ceiling and light its just over 2mb.
Thanks so much,
Lee
Thu, Oct 11, 2012 at 7:14:08 AM | Can't copy Lights - "Can't place inserts outside of hosts. !
If you are doing one light, then just right click on it and pick create similar.
Thu, Oct 11, 2012 at 7:57:05 AM | Can't copy Lights - "Can't place inserts outside of hosts. !
leedeetee
Thanks so much for the reply.
This has worked for the creating lights within a module's ceiling, but when I try to copy the module itself using this method, I get the same error.
Any ideas?
Many thanks again,
Lee
Thu, Oct 11, 2012 at 7:59:41 AM | Can't copy Lights - "Can't place inserts outside of hosts. !
You can create the ceiling the same way... by picking the ceiling at the edge and create similar.  If you want to copy a ceiling and lights, then do that.  You have to pick all of them.  Then after placing, you can edit the ceiling if required.
Thu, Oct 11, 2012 at 8:39:29 AM | Can't copy Lights - "Can't place inserts outside of hosts. !
leedeetee
I'm really sorry but this isn't working for me.
I have uploaded the file here if this is easier for you to see my problem. http://www.sendspace.com/file/95xeg3
I basically need to take the whole module and copy it over so that I can remove the long wall, and replicate each 'middle slice' so that I can create modular buildings of various lengths.
Does this make sense? Apologies if not.
Thanks again.
Thu, Oct 11, 2012 at 9:42:00 AM | Can't copy Lights - "Can't place inserts outside of hosts. !
sllana
5 Stars: 2 Votes
Try making it a "GROUP" and then copying it.
Thu, Oct 11, 2012 at 9:43:50 AM | sllana
leedeetee
Quoting sllana from 2012-10-11 09:42:00
 Hi Silana,
I've tried doign this also but it doesn't work either. I've no idea what I'm doing, and am now doubting whether it even can be done!
Thanks
Edited on: Thu, Oct 11, 2012 at 10:17:11 AM
Thu, Oct 11, 2012 at 10:12:48 AM | Can't copy Lights - "Can't place inserts outside of hosts. !
I don't have any problems copying ceilings with lights alone or if they are included in a group.  So if you are having problems, there is something else you have not told us.
I will not download from that site.
Thu, Oct 11, 2012 at 11:24:17 AM | Can't copy Lights - "Can't place inserts outside of hosts. !
quinn
there is a an easy way to ensure the copy.  save detach file relink back in then bind and ungroup it....done!
curve ceiling
Tue, Jun 28, 2005 at 11:28:48 PM
wall won't accept door style
Tue, Aug 15, 2006 at 2:07:53 PM
wall wrapping at curtain wall "inserts"
Tue, May 20, 2008 at 6:29:51 AM
The Lights are On (but nobody's home)
Thu, Nov 20, 2008 at 8:34:07 AM
'forms' not available in 'in place mass' or components.please help
Fri, Aug 30, 2013 at 3:20:58 AM
Page generation time: 0.9649
