Forums >> Revit Building >> Tips & Tricks >> Press&Drag
Thu, Oct 11, 2012 at 4:39:59 AM | Press&Drag
sagboy
Dear ALL
I'M anewbie for revit2012 architect. have a curious in this command is in the corner below right hand side.
Have anyone know how to use this function. Maybe this is very stupid question for all of you but please advice for me please.
Thank you very much for your time.
Thu, Oct 11, 2012 at 7:11:26 AM | Press&Drag
We don't typically use that function.  I encourage our users to turn it off because of inadvertent object moves.
Thu, Oct 11, 2012 at 7:49:26 AM | Press&Drag
sagboy
can you explain this function how to use for me please?
if we check in this box what we xan do or if we uncheck what we can control
thank you so much
Thu, Oct 11, 2012 at 7:52:54 AM | Press&Drag
Did you know there is a built in Help in revit?
Search for drag and you will find:  TipWhen moving elements one at a time, select Press & Drag on the status bar to drag an element without selecting it first. When using this option, the element is selected as you drag it.
Thu, Oct 11, 2012 at 9:00:40 AM | Press&Drag
sagboy
Thanks for your kind
Tue, Oct 16, 2012 at 1:43:13 PM | Press&Drag
saggynutsack
3 Stars: 2 Votes
curse off these forums are for expert architects only
printing press
Wed, Dec 29, 2010 at 11:28:44 AM
One click Object moving
Mon, Dec 6, 2010 at 7:36:12 AM
Duct Systems.
Mon, Aug 5, 2013 at 7:48:16 AM
Hi Press & Lo Press Dom Cold Water
Wed, Nov 11, 2009 at 9:19:49 AM
Anchoring Keynotes
Mon, Jan 17, 2011 at 7:16:23 AM
Page generation time: 0.6504
